Looking for some flywheel opinions, turn the OEM, or Advance Auto $115 China Wheel
Old Nov 18, 2015 | 02:09 PM
85 Frankenstein's Avatar
Car: 1985 Camaro Z28
Engine: 1988 305 TPI
Transmission: 1993 T-56
Axle/Gears: 3.08
Hello,
I was hoping I could get some solid advice to do. The flywheel is for my 93 M29 T56, the OEM LT1 style with the pull clutch. I bought a new one from Advance Auto and when comparing it to the old one the casting seems like it is very course, it just does not strike me as being the same quality as the OE one.
This is the link for the new one:
http://shop.advanceautoparts.com/p/p...15053|L3*16362
The OE flywheel, if I put this one back on, will be turned twice in all.
I was just wondering if anybody had any opinions or thoughts on this topic. I am not quite sure what to do.
Put on the new one from advance auto, or get the OE flywheel turned again and reinstall this one?
Thanks for any input.
Old Nov 18, 2015 | 05:13 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Looking for some flywheel opinions, turn the OEM, or Advance Auto $115 China Whee
IF the OE meets min. thickness specificiation after turning, run it.
Old Nov 19, 2015 | 02:01 PM
danryanm's Avatar
Car: '86 Trans Amvanian Frankenbird
Engine: 350 4bbl
Transmission: T5 4.03/.76
Perfection Clutch makes good stuff. If you ever run into an issue, their support line is the best. (I called them for spec numbers when cobbling my frankenstein setup together.)
Old Nov 19, 2015 | 02:25 PM
big gear head's Avatar
Don't turn a flywheel on a lathe. Have it ground. I'd much rather have a resurfaced original flywheel (as long as it isn't cracked) than a China flywheel.
PurelyPMD
Feb 20, 2016 07:24 PM
92rszz4
Nov 23, 2015 03:59 AM
luvofjah
Nov 16, 2015 11:32 AM
MikeCpa
Nov 14, 2015 11:18 AM
MikeCpa
Nov 14, 2015 11:06 AM
