gear selecter complication
Old Nov 19, 2015 | 07:20 PM
diante24's Avatar
This summer I bought a 86 chevy s10 2.8l engine for my 85 chevy camaro and then my trans went out 2 weeks ago. So I recently bought a 85 chevy s10 transmission for the same 2.8l engine but the only problem I have is where the shifter cable hooks up to the side of trans to select the PRND21 gears they are different. So I was wondering what I have to do to solve that issue so that I can be able to hook up the cable and change gears. I need help asap so that I can drive my car thanks I would really appreciate it.
Old Nov 20, 2015 | 08:09 AM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Re: gear selecter complication
Seriously? You seem to have figured out the need to transfer the Camaro's tailhousing because of the torque arm, but you can't loosen a 15 mm nut to transfer the shift arm?
Old Nov 20, 2015 | 09:46 AM
diante24's Avatar
Yes I did transfer my shifter arm on there now I just have to figure out how to mount the shifter cable that hooks to the shift arm.
Old Nov 20, 2015 | 01:15 PM
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Isn't there a bracket to attach the cable to the trans pan bolt holes just like a V8/700R4 car?
Old Nov 20, 2015 | 06:39 PM
diante24's Avatar
Yea it is hopefully that works
Old Nov 23, 2015 | 03:18 PM
I don't see why using the bracket wouldn't work... I doubt the F-body & S10 trans had different pan-bolt patterns, lol.
norcalz28
Jan 16, 2017 03:37 PM
theking11863
Oct 18, 2015 05:10 PM
yellowferrari
Oct 12, 2015 11:07 AM
86z89iroc
Oct 9, 2015 12:58 AM
SteelheadBen
Oct 3, 2015 12:08 PM
