10 bolt to 9" swap over.I have questions
Old Dec 21, 2001 | 09:52 AM
LILRED383's Avatar
I just received my new custom fit 9" rear end for my 92 Camaro. I would like to swap out the 10 bolt for the 9" myself, but I've never done it before, so if any of you guys can help me, I would really appreciate it. First off, do I need any special tools ( spring compressors etc.), and what kind of torque requirements are there. The new rear end has disc brakes on it, so I'll need any info on the drum to disc swap.Thanks in advance.
Old Dec 21, 2001 | 02:17 PM
crucial_82_Z28_283's Avatar
i have just done this swap .... well still doing this swap actully ..... as far as the rearend goes it is a direct bolt in .... i didn't have any probs with mine ..... thing is with mine is my driveshaft doesn't bolt up ....its about a inch to short .... but i also have a th350 ..... does anyone know the length if a stock 3red gen drive shaft out of a 700r4 car? or ven a 4th gen car ? .....
Old Dec 21, 2001 | 06:43 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Third gen driveshafts come in 2 sizes. Long and short. They're 3" different in length. If yours is 1" too short then you'll need to have a new driveshaft made or get a longer one shortened.
A good floor type jack and jack stands are about the only special tools you'll need. An impact gun will help and depending on how seized the panhard bar bolts, shocks and LCA bolts are, you may need some torches to heat them up first.
Old Dec 21, 2001 | 08:01 PM
irocbsa's Avatar
You will need to install an adj. proportioning valve for the drum to disc conversion.
bsa
Frozer!!!
Jan 19, 2024 04:55 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
