11" clutch on a T5? Need help!
Old Jan 1, 2016 | 09:45 PM
monte87cortez's Avatar
Car: 1989 Camaro Iroc-Z
Axle/Gears: Bw 9bolt 3.42
Ok I purchased a 168 tooth flywheel and center force 11"clutch with pressure plate from a guy said it was for a T5 trans I bought it with out even doing any research (my fault) will this work on my t5? my cars a 89 iroc with a 350 vortec and the only part number is see is on the center force Pp is #4425991. I've looked on there website and entered the part # and it didn't find nothing. Any help would help thank you and happy new year..
Old Jan 1, 2016 | 10:42 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: 11" clutch on a T5? Need help!
Every third gen V8 bellhousing fits a 153 tooth flywheel and 10.5" clutch.
There are two Lakewood scattershields (15020 for your car) that work and will accept the 168 tooth flywheel and 11" clutch. That change will require a different starter unless you have a special multi-fit starter that slides to fit the 168 setup.
oscarfromla
Oct 19, 2013 09:28 PM
jayk2k3
Oct 22, 2006 12:02 AM
MrsLottaBallsCamaro
Jul 17, 2002 07:22 PM
