Megashifter wont go into slap-mode
Subscribe
Jan 3, 2016 | 01:41 PM
Hi there,
I have a 91 Firebird with a 700r4 auto trans with a B&M Megashifter slap-shift kit on it. It has previously worked perfectly fine but now will not enter the ratcheting slap-shift mode. All other gears work fine and it shifts through them easily. It still goes into drive and drives fine in D but will not shift down further than that. Anyone else have this issue or have any ideas?
Thanks.
Reply 0
Jan 4, 2016 | 08:14 AM
Re: Megashifter wont go into slap-mode
Check on the piece and springs at the bottom of the shifter. There is a part that rocks back and forth for the ratcheting mechanism that is not working. I've had to spray lube on one before to get this to function again.
Reply 0
Jan 4, 2016 | 04:09 PM
OK, I will clean the whole ratcheting mechanism and use some lithium grease on it. What piece in particular is the one that would be causing too much friction?
Reply 0
Jan 4, 2016 | 10:42 PM
The one I had problems with seemed to be because it had some thick grease on/in it that was probably also somewhat dirty to the point where it was "sticky". Some cleaner and thinner lube and it was good to go. It also needs a little clearance under it since the ratcheting mechanism protrudes from the assembly a little bit during ratcheting motions only.
Reply 0
Jan 5, 2016 | 09:33 AM
OK, I need to pick up a new can of brake clean or some carb cleaner and I will spray it down and try to get it moving with some grease. If that doesn't work I will pull it out and soak it in hot water and get it to work on a bench.
Reply 0
Subscribe
