Bellhousing bolts
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Bellhousing bolts
I have to pull my bellhousing soon and I want to replace the random hardware store looking bolts with something better. Are these the correct ARP bolts
http://www.summitracing.com/parts/arp-129-0901
Underhead Length (in): 1.375 in.
Thread Size: 3/8-16 in.
Fastener Material: 8740 chromoly
Fastener Finish: Black oxide
Re: Bellhousing bolts
A bit on the short side, but should work fine. 1½" is OE if memory serves.
You can get entirely adequate flange-head bolts at Lowe's for a fraction of that price... not sure if you have any Lowe's in your area though...
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
dang... that's a lot of money for bellhousing bolts.. hit a junkyard and find some factory flange head bolts. they used the same ones in everything with a small block V8 or 90 degree V6 from the early 70's to the late 90's..
Thanks for the heads up, I grabbed some 1.5" long 3/8 -16 flanged bolts from lowes for about $0.80 each.
blunierdr
Mar 5, 2021 01:03 AM
