Swapping speed sensor to cable and tailshaft house ~ help please
Old Mar 9, 2016 | 09:00 AM
stephenscamaro's Avatar
Car: 1988 Camaro
Engine: 2.8 to 383
So the trans I am rebuilding has the sensor in the tail housing, I would like to remove this and put the mechanism for the cable speedometer. I know I need the new housing and the mechanism, but will the 1991 shaft work with the mechanism or "mesh" with the plastic gear on the shaft?
1991 4l60 (700r4)
Old Mar 10, 2016 | 05:17 AM
fokeyman's Avatar
Car: 89 IROC
Engine: l98 350 TPI
Axle/Gears: 373s
Re: Swapping speed sensor to cable and tailshaft house ~ help please
I just went through the same issue. But mine was 700r4 out of similar year fbird with vss. http://www.transmissioncenter.net/sp...__va.htm#700r4 and http://www.tciauto.com/tc/speedometer-gear-calculator/ for more info. If you need the 40+ driven gear, ebay has the housing+gear for around 40 bucks. The drive gear I got separately from ebay too. The 34-39 tooth housing is much cheaper.
Donald Croes
Mar 14, 2016 02:34 PM
Skwisgaar
Mar 9, 2016 06:52 PM
obarrt
Mar 9, 2016 09:39 AM
bryanwood74
Mar 9, 2016 09:34 AM
mrestrictrplate
Mar 8, 2016 03:30 PM
