Th350-->700r4
Old Dec 23, 2001 | 02:41 PM
3504mula's Avatar
Car: 90 Formula
Th350-->700r4
I am about to swap out my transmission with a better one and my dad was wondering if he coud use my old one (which was just rebuilt) in his '85 Chevy LB Silverado. He has a 350 in it now but it leaks pretty bad, and he could use the overdrive. My question is: Is this a direct swap, and if not how much work would it take to install? My main concern would be the length of the two transmissions.
Thanks for any info or past experiences.
Old Dec 23, 2001 | 05:36 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
Re: Th350-->700r4
for the most part yes. so long as the th350 has the 6" tailshaft, you won't need to replace the driveshaft. you will need to get a lock up switch from someone like b&m or TCI. also, if his truck is carburated, then he will need to get the TV cable bracket from a junkyard or TCI. the current TV cable may not be long enogh. they make a universal TV cable.
Old Dec 23, 2001 | 09:44 PM
Nordbert's Avatar
If the TH350 has a 9" tailhousing, the driveshaft will fit. If the
TH350 is a TH350c, the lockup wiring should plug on ( and if the
lockup on the TH350c worked, it should work on the 700-r4).
Use the TV cable and bracket for a 700-r4 , as well as a gear selector bracket and fluid indicator and tube for the pickup with
a 700-r4. The crossmember may be the same, but be prepared
to buy one at a salvage yard . If in doubt, ask your salvage yard counterman.
Old Dec 25, 2001 | 11:25 PM
3504mula's Avatar
Car: 90 Formula
Thanks a lot guys, that is what I needed to know.
Old Mar 21, 2005 | 09:14 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
uhmm a 700r4 is the length of th350 with 9" tail
6" tail is car length
6" tail th350 is 3" shorter than a 700r4
you guys shouldnt give wrong info out
Old Mar 21, 2005 | 11:07 AM
always tinkerin's Avatar
Car: 85 Berlinetta
Engine: 408 SBC with a S-480 Turbo
Transmission: TH350/Hughes converter (Thank Pete)
Axle/Gears: 3:23 28.5" tire
Just helped someone do this swap. Had to weld a small piece of metal to the crossmember for trans. mount, used the 700 detent cable (required different throttle cable bracket for carbureted application). Driveshaft yoke fit on tailshaft splines o.k. Can't remember any major difficulties-just took a bit of enginuity. Both transmisssions were nearly identical in length.(measured before even CONTEMPLATING swap) Trans. mount on 700 was about 3 inches behind 350 mount hole in x-member-no big deal to modify. Owner loves his new trans. Gotta love that extra-low, tire fryin first gear.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
