Simple brake switch question...
Old Apr 10, 2016 | 06:29 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
TCC isn't locking up. Since I dont have a test light, a multimeter did the same job. When the key is in the ON position, I have the test leads on terminals A and F in the ALDL. I get 12 volts. However, when the brake pedal is pressed, I still have 12 volts. Should go to zero I believe. Bad brake switch or just out of adjustment? Cruise control seems to work fine if that helps.
senior bear
Jun 8, 2019 03:55 PM
formula00ra
Apr 26, 2016 07:39 PM
jdost1992
Apr 11, 2016 12:31 PM
wgripp
Apr 8, 2016 10:35 PM
dfarr67
Apr 4, 2016 09:26 AM
