T5 swap parts list
Old Apr 12, 2016 | 08:05 AM
sgp0511's Avatar
Car: 1988 Firebird
T5 swap parts list
I have been searching everywhere for a complete parts list to swap a 700r4 for a T5 transmission. I got a used T5 from a friend and the day I picked it up my automatic transmission started slipping, it only slips when I step on the gas hard other than that it is still fine . So currently all I have is the T5 transmission I know I need the pedals and slave cylinder. What all do I need to buy to make this swap complete. And also is there a way to check a used T5 without opening it up to make sure it is still good? I don't want to rebuild the T5 but I will just clean it up and are there any seals or gaskets that I should replace because the transmission has been sitting in a shed for years. The T5 was removed from a 88 Camaro 305 and my car is a 88 Firebird 305 .
Old Apr 12, 2016 | 08:39 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: T5 swap parts list
Bell housing
Clutch fork
Pedals
Master and Slave cylinder
Shifter
Flywheel
clutch
throwout bearing
pilot bushing
Speedometer gears and vss
Most of this stuff you can get on rock auto.
The only thing you can inspect the input and output shaft play without taking apart the case. The easiest thing to do it pull the tail shaft and cover and look at the gears and syncros.
