T-56 shift location question
Old Apr 3, 2016 | 12:40 AM
Numbah-1's Avatar
Car: 1984
Axle/Gears: 10 bolt
Hi guys, I have a question for the T-56 swaps owners. My 84 came with a working T-56, but the shifter is extremely far to the right. Its almost against the center counsel is 5/6th and I had to hit the side of it for reverse. I seen where online170 said it needed to be cut further back to get it in, but not left to right. Is this a common problem and are there any solutios?
Old Apr 3, 2016 | 01:17 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: T-56 shift location question
Depends on the shifter.
The stub in the aftermarket Hurst was straight.
Nearly identical, the one in the OEM/SLP installed Hurst was bent towards the driver.
Pics of what you have will help determine solutions.
Old Apr 12, 2016 | 10:52 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
My Pro 5.0 shifter is obviously angled towards the driver's side. The actual stick itself is machined at an angle where the stub is vertical. Probably just depends on what shifter you have.
So how is your shifter set up?
Old Apr 12, 2016 | 12:27 PM
BOTTLEDZ28's Avatar
Transmission: A4
I ran a Lous Short Stick and stock shifter base on my last car and it was perfect.
Get us a picture of the shifter youre using as well as where it sits when the trans is in 1st, 2nd, 6th and reverse.
greasegrenade
May 8, 2016 02:22 PM
Black_TA
Mar 20, 2016 09:54 PM
mclenty0
Mar 18, 2016 09:11 AM
marz1129
Mar 10, 2016 04:34 PM
SRKLEGIN
Mar 7, 2016 06:40 PM
