Driveline Cover
Old May 12, 2016 | 06:41 AM
stegal's Avatar
Car: 1990 RS, 2002 Chev Silverado
Driveline Cover
Hi
What is the long flat angled metal piece beside driveline on car. It is between transmission and rear end.
Does it help with engine and rear end torque? Is it for protection?
Just wondering?
Old May 12, 2016 | 06:54 AM
Re: Driveline Cover
It's called "torque arm".
It's a major piece of the rear suspension. It holds the rear end in place. It's kinda like the upper control arms on a 4-link rear, such as in a Chevelle or Monte Carlo or Caprice. Without it, there's nothing keeping the rear end housing from rotating.
Old May 12, 2016 | 07:30 AM
stegal's Avatar
Re: Driveline Cover
Maintenance link? Youtube
Old May 12, 2016 | 07:31 AM
stegal's Avatar
Re: Driveline Cover
May be part of rear end noise bothering me on sharp bumps.
Old May 12, 2016 | 07:36 AM
Re: Driveline Cover
Should be bolted securely to the rear end, and in a rubber bushing assy at the transmission end. The rubber piece can and does disintegrate. Poly replacements are available. But "sharp bumps" isn't what usually makes it make noise; rather, going from accelerating to braking does it.
Noise on bumps is more likely the floor pan punched out around the top shock mounts.
Old May 12, 2016 | 08:11 AM
stegal's Avatar
Re: Driveline Cover
It is not the torque arm.
I will check shock mounts.
Old May 12, 2016 | 05:01 PM
stegal's Avatar
Re: Driveline Cover
jacked and checked underneath. Tried bolts and looked at mounts. All seems good.
Took pictures sprayed some rust. Very little.
Dropped onto ground and pulled spare tire cover.
SPARE WAS LOOSE. dumb ***!
Shock mounts don't make noise show any signs of problems.
Drive this evening with just spare in back and listen to the car.
It sounds really good for a 1990.
Have had it for year. Yeah.
ENJOY the morning and evening drive.
NO A/C
astout82
Apr 28, 2016 10:11 PM
hotrodaj
Apr 25, 2016 02:33 PM
Black_TA
Apr 20, 2016 05:22 PM
Aaron R.
Brakes
Apr 19, 2016 02:33 PM
KoriNoKage
Apr 18, 2016 01:01 PM
