Noises
Old Jun 7, 2016 | 12:02 PM
audioc's Avatar
Car: 1986 trans am
Transmission: 5 speed
Noises
I have put in a new torque arm, relocation bracket and new trans mount on my 1986 trans am. I have a t-5 manual. When I accelerate and let off the gas I hear a clunking noise. The u-joints are good and have had the rear end checked out. Any Idea's. I have also non adjustable rear control arms.
Old Jun 7, 2016 | 02:31 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: Moser 12 bolt, 4.11's 33 spline axl
Re: Noises
Are you sure the trans mount bolt(s) are tight? That's what it sounds like when the mount is broken or the bolt falls out. At least, it's the simplest thing to check first.
Old Jun 7, 2016 | 05:22 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Noises
IDK if its any help but, under acceleration the torque arm will be trying to push up. letting off the gas, (when you say your hearing a clunk), the torque arm would be trying to move downward.
might help isolate the problem some?
Old Jun 8, 2016 | 08:50 PM
Re: Noises
To Joe's point: what torque arm did you use? What crossmember?
383 has good suggestions, but it sounds like you've already covered those. No harm in going back and double-checking though.
Old Jun 9, 2016 | 09:13 AM
Car: '91 Camaro RS
Re: Noises
Ditto what these guys are saying, anything with the torque arm/torque arm mount could do that for a variety of reasons including being loose, hitting the trans tunnel/trans, the adjuster being loose, if it's adjustable.
Old Jun 10, 2016 | 01:00 PM
audioc's Avatar
Car: 1986 trans am
Re: Noises
Torque arm is tight. That was what i thought also. Is there any way slop in the tranny could cause this? (t-5)
Old Jun 10, 2016 | 01:02 PM
audioc's Avatar
Car: 1986 trans am
Re: Noises
Umi adjustable torque arm and tranny mount with torque arm relocation
Old Jun 10, 2016 | 06:18 PM
Car: '91 Camaro RS
Re: Noises
Hmm ... if there was enough slop in the rear end it could do that. Is there anything going on back there?
Old Jun 12, 2016 | 07:45 PM
audioc's Avatar
Car: 1986 trans am
Re: Noises
When i had the rear end out i had it checked and was told it was ok?I'm starting to lose the fun part of this rebuild!!
Fechin
Exterior Parts for Sale
16
Dec 27, 2016 05:53 PM
bigarmzz
Jun 25, 2016 04:36 PM
jeremy iroc z28
Jun 25, 2016 01:08 PM
G8nightman
Jun 7, 2016 09:43 AM
Mikeb297
Jun 4, 2016 09:03 AM
