GM or B&M 2000 stall?
Old Dec 26, 2001 | 12:20 AM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I'm leaning towards the GM stall just 'cause it's a factory unit. I wanted your opinions before I blow the much saved $220. They're the same price, just a matter of which one.
Old Dec 26, 2001 | 04:24 AM
transfixleo's Avatar
I've used the GM and it is a fine piece. I would use that.
Old Dec 26, 2001 | 05:06 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I'd use just about anything before I'd put a B&M part on my car.
Pro Built Automatics's Avatar
I'm with transfixleo on this one (no comparison) if this what you want, then GM all the way (I can't believe I said that). B&M has no quality control on their TC's, and the last I heard their comeback rate was near 40% (this is not a joke). Personally I do not like 12" TC's, but I would go for a higher stall from GM (Corvette for example), as I do not think you will notice any difference, unless your stall is only around 1,500 rpm now.
Old Dec 26, 2001 | 12:53 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
Right now my stall is like 1100 RPM or something stupid like that. Just after I posted this I was on B&M's website. Their application chart said you could not tow with their 2000 stall. What a bunch of crap. So I got my GM part number out and called the dealer. I can't imagine GM would put this converter in the S-10 and then say you can't tow with it. They say this stalls at 2000 RPM on the 4.3. The guy I got the PN from said it stalled at 2100 in his stock Impala SS.
GM 2000 stall - 24202310
Old Dec 27, 2001 | 03:32 AM
Remember that in an S-10 it will have lower rear end gears which in turn will allow for the higher stall W/O the problems that a high geared car would have. If you have, let's say, 3.42 gears you will be fine.
Old Dec 27, 2001 | 07:03 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Go with the GM converter. I have the Corvette TC in my GTA and like it a lot. It made a noticeable improvement.
Fireslash
Apr 11, 2016 06:43 PM
kammi10
Nov 9, 2015 08:28 PM
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
