86 Trans Am Auto to manual transmission swap
Old Jun 20, 2016 | 05:30 PM
Reborn756's Avatar
Car: 1986 Trans Am
Engine: 305 Carb.
Transmission: TH350 non-lockup
Axle/Gears: 2.73 rear gears
Howdy folks, Reborn here looking for some advice.
So, as the title says, I'm considering swapping out my TH-350 for a manual transmission. I can get a working Super T-10 locally for a decent price, but before making the decision, I wanted to know if any of you folks have swapped a T-10 into your auto Third gens. If any of you have, how difficult was the swap to do, and what needed to be replaced/modified to make it fit?
The car currently has a 305 in it, but I'm going to be pulling it out in a month or so and replacing it with a 4 bolt main 350. The ECM and all of that crap has already been eliminated off of the car.
Thanks in advance for your help folks!
Old Jun 21, 2016 | 08:52 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: 86 Trans Am Auto to manual transmission swap
You need to make provisions for the torque arm. There are a few threads about it the general consensus is there are newer and better options.
You will need a new flywheel, clutch, pedals, hydraulics or cable assembly along with the supporting parts. You may need a custom drive shaft depending on lengths and shaft spline counts.
Old Jun 22, 2016 | 07:54 PM
Gfunkill's Avatar
Car: Sport Coupe
Engine: 3.4 MPFI
Transmission: WC T5
I would recommend if possible to get a t5 bellhousing and tailshaft from an fbody. I heard someone complain somewhere that they didn't get the angled one and it wasn't pleasant. But I don't know jack about t10's so I dunno if that's possible.
I did the swap from a 700 to a t5, and I love it.
The worst part for me was swapping pedals. Laying backwards on my seat with my head under the dash was NOT fun.
Good luck.
86ZRESTO
May 21, 2018 08:33 AM
BG1959
Jul 20, 2016 02:22 PM
neely8
Mar 27, 2016 01:17 PM
GetTrucking
Mar 25, 2016 10:01 PM
ottfive
Mar 25, 2016 10:15 AM
