92 Camaro Having Trouble Changing Gear
Old Jul 1, 2016 | 05:24 PM
chriskovach's Avatar
I have stock automatic transmission. The car switches gear from say park to reverse or drive or any of the other combinations fine and when accelerating the car gets through first gear with no problem even with the hammer down however when going into second or third the rpms begin to waiver moving back and forth and unless I ease up on the gas the car refuses to shift. Even then I feel a significant loss of power. My transmission fluid level is fine and has been recently changed out with some lucas stop slip additive. Is this the result of a bad filter? A bad solenoid? I’m at a loss and will be bringing it to my usual mechanic next week when he returns from vacation however I’d prefer to handle this myself.
Old Jul 2, 2016 | 01:49 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: 92 Camaro Having Trouble Changing Gear
Why was Lucas introduced? Was it a preventative measure or an attempt to fix something?
Old Jul 2, 2016 | 01:55 AM
Preventative but with the way it's running im thinking its the solenoid. While i have the pan down tomorrow I'll be replacing the filter and obviously putting in new fluid without the lucas so it doesn't through off the viscosity.
Old Jul 2, 2016 | 01:56 AM
And of course testing and if need be replacing that solenoid
adamcgodby
Jul 16, 2023 11:48 PM
90Iroc_Coup
Jul 30, 2016 11:33 PM
Project 3.4 Camaro
Camaros Wanted
Apr 8, 2016 06:37 PM
RedLeader289
South East Region
Apr 7, 2016 06:55 AM
