T-56 Close or Wide Ratio?
Old Jul 8, 2016 | 07:51 PM
Crossfire1983's Avatar
Car: 1983 Chevrolet Camaro Z28
Engine: LS3
Transmission: Tick TR6060 w/ Mantic 9000 clutch
Axle/Gears: Strange S60 w/ 3.73 True Trac
I can't seem to find any concrete testimonial on which would be best for my applications. The car is going to be a street/strip car with occasional road course use. The rear end will be a 12 bolt with a 3.73 but depending on which trans ratio I go with I may get a 4.10 instead. Motor will be a 525hp crate LS3.
Old Jul 8, 2016 | 11:31 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: T-56 Close or Wide Ratio?
Are you going with the T56 Magnum?
The closer ratio box is probably a better match for the build.
5th & 6th can be changed at a later time if you decide you want more OD.
Old Jul 9, 2016 | 07:37 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
for what its worth I would not go with the 12bolt and a 6-speed.
Old Jul 9, 2016 | 04:27 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
The T56 comes with a few different gear sets. So its hard to say without knowing what T56 you are getting.
My T56 uses the M28 gear set. So its pretty short in 1st.
3.36, 2.07, 1.35, 1, .80, .63 ratios.
What road courses are you going to run? You may want to avoid the 4.10's if you are going to see extreme speeds that require the use of 5th or 6th gear. This is because your drive-shaft will be operating at over driven speeds.
With my M28 gearing, a 3.23 final drive, and a 7000rpm rev-limit 4th tops out around 160mph @ 6800rpm, and 200mph in 5th.
If I went with 4.10's it would mean I'd be spinning the driveshaft 8600rpm in 5th gear @ 160mph.
At Road America where I would be running I just am not comfortable with the idea of spinning the driveshaft that fast.
So the most I'd do is probably a 3.73. It would keep the driveshaft speeds down to a safer level.
Old Jul 9, 2016 | 09:11 PM
2slow5.0's Avatar
Car: 91 Formula
Engine: 5.0 tpi slow
Transmission: WC t-5
Not to jack this thread, but why?
Mark Walker
Apr 14, 2016 12:06 AM
i88aGT
Apr 6, 2016 06:53 PM
Gambit TA
Apr 1, 2016 05:18 PM
Cm87pta
Aftermarket Product Review
Jun 6, 2001 03:57 PM
Rallyssport
May 17, 2001 03:58 PM
