A 700R4 - 15 years in the making
Old Jul 13, 2016 | 12:09 PM
WmMcNett's Avatar
Not really a 3rdgen related but I've always ended up here in my searching for information.
I'm working on my 87 Aux vb 700r4 for my 87 S-10 with a 383, that I built back in 02 and made 310 hp @ 5,300 - 371 ft-lbs @ 3,200 at the rear wheels on the chassis dyno.
I had put an Art Carr kit in it when it had a stock 350 in it and started buying parts to rebuild it after I built the 383.
Last spring I finally got around to put the cheap Dacco high stall converter, that’s been setting on a shelf in the garage for 10+ years in it. I was loving it, then something happened. I'm guessing the converter clutch fell apart.
Back then I bought a bunch of parts from Makco, PAC, Bowtie Overdrives, Sonnax, .......
ALTO HP Master Kit, 700-R4 w/ Red Eagle Friction & Kolene Steels
Torque Drive products input drum and reaction shell
5 pinion planets, front appears to be GM, rear is defiantly after market
Superior servos, Hydraulic Lock-Up Package (Superior K017 ), Shift Point Package (Superior K018 )
Just about every Sonnax part that was available
Kevlar wide band
After I got this tore down, I noticed NEWER parts where available :-)
So, I bought them, lost of shopping around, eBay, amazon, rock auto, ........ ;
Sonnax 2nd Gear Super Hold Servo Kit, 4th Gear Super Hold Dual Servo Kit, 2.84 Ratio Input Carrier Kit, Billet Forward Clutch Piston, Smart-Tech Input Housing Kit with Heavy Duty Input Shaft, SmartShell® Heavy Duty Reaction Shell Kit, both L-K & M-K Accumulator Valve Train Kits
Lots of new ACDelco parts, 5 pinion rear planet 24228763, Overrun Clutch Spring 24206085, Internal Reaction Gear Support 24225931, Steel Low and Reverse Clutch Plate Kit 8687996, ...... revers input turbulator steels, 24241477 Sprag Assembly, 24221190 Shell Kit, 3rd accumulator check 8634400
Alto 057757DX G3 3-4 Clutch PowerPack, 057758 Reverse Input Drum Saver, wide carbon band
Superior 3-4 Clutch Rapid Relief Valve (Superior K070 )
200/325/325-4L Direct drum front bushing
350 pump bearing, ACDelco 9436851 (09436851)
Both Transgo kits, 700-2&3, SK 700
Both Superior kits, 700-R4 Kit (Superior K700-R4 ), TransAction Kit (Fairbanks 70015 )
Adapt-a-case center support
Other parts I've forgotten to list
It's basically together, and I'm debating on what to do with body. Because of the Art Carr kit, I also bought Transgo's separator plate because I'm sure some holes are TOO BIG.
After some reading, I ordered the newer output shaft seal and a Transgo 7-300 0.300" low/revers/intermediate boost valve. So, I'll be pulling it back apart to install that seal.
Also debating installing the Transgo 7-CS kit even tough I'm using the boost springs in the Sonnax input drum and my current cam starts falling off @ 5300
Don't really want to go drilling holes in the VB or have full manual. So, that leaves me with the Transgo Sr kit, Fairbanks, and Superior kits.
3-2 control valve, Transgo spring it too long, too stiff?
MTV up valve, Art Carr had me remove, Transgo?
MTV down valve, Superior's is stiffer
B accumulator valve, replace with Sonnax, Transgo spring?
Line Bias valve, block, Transgo spring?
Had to remove about 1/8" off the Sonnax servo pin to get me close to the min 0.075" spec, did that on the cnc lathe and turned a 5mm radius.
Ready, Set, Go
jdumas
Jun 5, 2016 07:14 PM
85@IRocZ
21
May 17, 2016 08:03 PM
3rdgenparts
Exterior Parts for Sale
May 13, 2016 08:56 AM
dpmalibu
Apr 23, 2016 03:59 PM
Black_TA
Apr 16, 2016 07:33 AM
