world calss t5 rebuild kit?
Car: 1990 RS Camaro
Engine: 400 sbc throttle body
Transmission: world class t5 manual
Axle/Gears: 3.73's, Detroit TrueTrac
where can I get a COMPLETE rebuild kit for my world class t5 (camaro V8). i dont want to go cheap so price isnt a big deal i just want a good kit with a good brand, i just cant seem to find anything. Any help would be great thanks.
Car: `86 SS / `87 SS
Re: world calss t5 rebuild kit?
http://www.thegearbox.org/T5.html
Gears and synchronizers aren't replaced unless they're worn beyond use.
You should tear it down, inspect the front bores for the bearing races in the case, and the rest of the parts before ordering.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
You may also want to get the cluster support plate made from steel $60 and consider the gforce reinforced case for $280 if price is not a big deal.
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
I just went thru mine with this kit:
http://www.thegearbox.org/catalog/it...32/3531872.htm
Had everything I needed.
To clarify,
Synchronizer blocker rings, synchronizer struts/"Keys" and springs for the keys are a normal part of a rebuild kit.
The synchronizer assemblies consisting of slider & hub are commonly re-used.
Car: 1990 RS Camaro
thanks for the help guys. i Know my 5th gear synchro is completely gone. as for my gears i am almost sure they are good i have had this trany built 2 in the last year so i figure its time to do it my self to know it gets done the right way
If you are tearing it down to the case you may want to contact GFORCE and get their upgraded case and bearing retainer for about $325.
