Which rear end for a 383??
My rear diff. has been noisy for awhile.which rear end should I look for, to go with a 400 horse 383 I'm thinking of putting in my car?Will any stock ones hold up? Ie: from a wrecking yard
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You'll need to find one from another third gen.
The 10 bolts are all roughly the same. Subtle changes were made over the years. The 90-92's have the larger 28 spline axles. You can beef up any third gen 10 bolt to take a lot of abuse. I ran one all during the 2001 race season and have just recently put in a ford 9".
You could try looking for a Borg Warner 9 bolt. They were the heavy duty diff offered in some models like 350 IROCS and WS6 cars. Many are only 2.77 gears. Try to find a 3.27 or 3.45 (3.42) geared one.
The ultimate is finding a third gen Dana 44 diff. You can still buy them from places like SLP but for the cost you might as well buy an aftermarket 12 bolt or 9"
When I had my 383 running high 11's I was still using a BW 3.27 geared 9 bolt.
This is a daily driver,so are you saying I could just rebuild my current diff.and probably be ok?I don't plan to take the car to the track.I have too many other hobbys as it is.
Thanks.....
Thanks.....
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
LT1Formula
Aug 20, 2015 09:36 PM
AkDrifted
Aug 17, 2015 07:45 PM
