4l80e swap
Old Oct 17, 2016 | 06:53 PM
90' 305TBI's Avatar
Car: 1990 Camaro RS
Engine: 5.7
Transmission: 4l60e
4l80e swap
What is all needed exactly to swap a 4l80e into a 3rd gen Fbody? Will there need to be modifications to the floor pan? Thanks
Old Oct 17, 2016 | 08:05 PM
jpearcy1's Avatar
Car: '87 Iroc
Engine: 350 TPI with Holley Terminator X
Transmission: 4L60e
Axle/Gears: Stock/ Factory
Re: 4l80e swap
A 4l80e will fit with little modification to the trans tunnel. Your biggest issue will be the transmission cross member, for no company currently makes one to fit the 4l80 that I know of. Search and you will find multiple threads of people detailing how they made one
Old Oct 18, 2016 | 06:12 AM
W72's Avatar
W72
Car: 89 GTA & 92 T/A covertible
Engine: 408LS-SC, 355 TPI
Transmission: 4L80e, 700r4
Axle/Gears: 12 bolt, 9 bolt
Re: 4l80e swap
I did it, and as jpearcy mentions you'll have to fab up a crossmember , figure out a torque arm mount and probably shorten your Torque Arm.
Depending on headers or Y-pipe you'll get creative with exhaust too. It all fits, be it snug for sure.
I've read that the factory shifter doesn't work with the 4L80 but I didn't read that until I got mine to work just fine with it. I did use linkage parts from a 700r and the 4L80e to get the "sweep" of the selector right, but it works fine.
Old Oct 20, 2016 | 05:31 PM
90' 305TBI's Avatar
Car: 1990 Camaro RS
Engine: 5.7
Transmission: 4l60e
Re: 4l80e swap
So other than crossmember, torque arm mount, and floor pan i should be good? Will the stock driveshaft work with the 4l80e? Or would i need a new one? Thanks
Old Oct 20, 2016 | 05:42 PM
W72's Avatar
W72
Re: 4l80e swap
No, it'll be too long because the 4L80 is longer over all. Have one built with the bigger yoke anyway or for use with a conversion U-joint.
Old Oct 20, 2016 | 05:46 PM
W72's Avatar
W72
Re: 4l80e swap
And because my Crossmember was further back I ended up modifying the tails of the sub frame to use an extra mounting point on each side.
there is some discussion as to the increased leverage it puts on the subframe so I added a wing tabs(?) to use the forward most factory mounting point.
Old Mar 28, 2017 | 09:01 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: 4l80e swap
Hooker sells a new "Black Heart" set up that includes their LS swap motor mounts and their LS swap trans mount. They have an adapter for the 4L80.
Arctic White 91 RS
Convertibles
Jan 9, 2017 09:16 PM
Alaska Hwy 1Le
Jan 2, 2017 04:30 PM
gholian
Sep 20, 2016 02:05 PM
JohnBoothe
Sep 18, 2016 02:24 PM
DirtShaman
Sep 18, 2016 12:52 PM
