HELP!! cracking in rear output housing
so i was wondering if anyone knew/or has dealt with this, they seem to be only at the surface but i know heat could possibly make them worse. should i just get a new tranny?
Re: HELP!! cracking in rear output housing
Not seeing a "crack"; just normal casting shrinkage surface marks, kinda like if you're baking something like biscuits or whatever and you pull it out of the oven and after it sits there, looks about like that; same physical process; can you point out what you think is wrong?
oh really? sweet, i was mostly just curious about those marks because i havent done much with transmissions and figured nows the time to start learning.
thanks sofakingdom
thanks sofakingdom
Yeah that's pretty much what they all look like. Castings in general. Aluminum especially.
