Too much sucks
Subscribe
Dec 7, 2016 | 10:41 PM
I overfilled my 700r4 on my 85' Caprice and every since it won't catch a gear. No reverse no drive. Only n & p. A guy at O'Riley's told me once I drain the excess fluid I'll be fine, just wanted some confirmation before I go do it in the morning where my baby is stranded
Reply 0
Dec 8, 2016 | 08:29 AM
Re: Too much sucks
i doubt draining fluid out is going to make it go in gear.
my first steps would be to make sure the shifter linkage is actually moving on the transmission.
then i would pull one of the transmission lines off at the radiator, (or cooler if you have one), start the car and see if its pumping fluid. it should pump very fast and about spray every where.
Reply 0
Dec 8, 2016 | 11:39 AM
Re: Too much sucks
I just had the shifter cable end fall off the trans. I would definitely check that first. If you look under the drivers side you can see if the cable is on the shift linkage. The shifter will move freely if the cable fell off.
Reply 0
Dec 14, 2016 | 12:51 AM
Re: Too much sucks
"If" you lost all the gears at once, it will be the rear end has broke or most likely the front pump quit (broke).
Reply 0
Dec 14, 2016 | 09:41 AM
Re: Too much sucks
Eeeeeeezy enough to remove some fluid.
http://www.harborfreight.com/catalog...t?q=drill+pump
Not likely however, that it will fix your problem.
This is a forum for 82-92 F-body cars, not Caprice (B-body) or G-bodies. We'll be nice and help you out ONCE though.
Reply 0
Dec 14, 2016 | 04:09 PM
Re: Too much sucks
It is a 3rd Gen Caprice. That counts for a little.
Reply 0
Dec 14, 2016 | 07:16 PM
Re: Too much sucks
65 - 69... (my late little bro had a 66 back in the early 80s for awhile)
70 - 72...
73 - 76... (I still have one of those, 74 convertible 454)
77 - 8x... (85 is in this generation)
Then acoupla more...
I guess my 74 is a 3rd gen?
Reply 0
Dec 15, 2016 | 05:02 PM
Re: Too much sucks
We already helped you out when GM needed a platform to modify to build the third gen.
Sorry about the clutch linkage thing though.
Reply 0
Subscribe
