rpm
Old Dec 20, 2016 | 05:21 PM
junglejim75686's Avatar
Car: 92 Z28 CONVERTIBLE
Transmission: AUTO
rpm
ok guys i know this has prob been beat to death but im thinking of changing my 92z vert auto gears to either 3.23 or 3.42 the problem is with the 2.73 gears now and 245/50/16 the tach shows 2250 at 70 and the calculator at wallace racing says it should be 1749 and 2191 with 3.42 gears also my 94 c1500 with 3.42 gears and auto shows 2400 at 70 with 275/60/15 and the calculator shows it should be 2011. both tachs shouldnt be wrong so what am i missing. thanks in advance for the help
Old Dec 20, 2016 | 06:39 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: rpm
The car is old.
Parts get changed.
Your diff. / ring and pinion could have been changed. A fluid change with gasket is cheap, and you could count the teeth to be sure.
The speedometer gears that drive the VSS could have been changed. Those are pretty easy to inspect and count.
Then, you'll know whether your tach is off.
Old Dec 20, 2016 | 07:53 PM
Transmission: AUTO
Re: rpm
nothing has been changed its been in the family since it was new and i hooked anther tach up to double check and it reads the same. thats what gets me is i know the car and also my truck is showing diff from the calculator also
Old Dec 21, 2016 | 07:40 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: rpm
Your speedometer could be off. Torque converter could be slipping. You don't have what you think you have. You can't do math. All these are possibilities.
Break the problem down into every little piece that could effect the results, verify each piece and you'll find the discrepancy.
Old Dec 21, 2016 | 08:05 AM
Transmission: AUTO
Re: rpm
I understand what your saying but I have used gps for speed on both and used another tach on the camaro and punched in on the calculator .7 for the overdrive gear so I'm not sure what the issue is. Does anyone else use the calculator at Wallaceracing.com
Old Dec 21, 2016 | 01:29 PM
1987L69's Avatar
Car: 1984 Z28
Engine: LG4 305/4bbl for now
Transmission: 5-Speed
Axle/Gears: 3.23 Posi
Re: rpm
Is your tire size stock? it should be a 26" tall tire.
Old Dec 21, 2016 | 02:26 PM
Transmission: AUTO
Re: rpm
25.7
