700R4 pump
Car: 1985 Z/28
Engine: L98 Carbed
Axle/Gears: 9 Bolt Posi 3.45
700R4 pump
I'm putting a transgo correction kit in my 1985 Z28 and I'm having some problems with the pump. I got alll the modifications done to the pump, but when I went to reinstall it, it would not line up. I finally got all that squared away without forcing anything. Not it slid in effortlessly and I used the bolts to seat it the final 1/4". My question is this, am I suppose to be able to turn the pump shaft by hand? I hope I didn't bind anything up because it feels like it won't budge?
Car: 1985 Z/28
Engine: L98 Carbed
Re: 700R4 pump
Hopefully I was freaking out about nothing. It turned just fine with the Converter on. Thanks!
Axle/Gears: '01 3.42 10 bolt
Re: 700R4 pump
torque converter won't turn the input shaft when turning by hand. it requires fluid pressure. only way it would do it if turning by hand is if the torque converter was locked up all the time.
Re: 700R4 pump
Ok Friends , I think a bit of clarification may be needed here .....First off , there is no "Pump shaft" . The two splined shafts sticking out of the pump area have nothing to do with driving the pump whatsoever . The outer one is supposed to be fixed solidly and unturnable as that is what holds an internal feature of the torque converter stationary . The inner one is supposed to turn as that is the actual "input shaft" that turns the transmission's internals . So , how does the pump get driven if it's not from one of those two splined shafts ?
A look at these pictures will explain it perfectly . If you look at the area of the torque converter that goes into the pump you'll see two notches . Those two notches engage the pump and turn the pump rotor with the two tabs seen in the pump internal picture (It is those two tabs that get broken when someone tries to bolt the transmission to the engine without first having properly indexed the torque converter so that it seats all the way into the pump to properly engage the tabs) .
So , since there is no way to attempt to turn those two little tabs without using the torque converter in it's proper position , I'm left to figure you were trying to turn one of the two prominent splined shafts when you said you couldn't turn the "pump shaft" . Now that we've got that straight , the bigger outer spline had best not turn since it's bolted solidly to the pump body and the inner spline (the actual input shaft) had best be able to turn else something is bound up in the transmission's inner workings .
I hope this made the operation of the pump clear ......
Car: 1985 Z/28
Engine: L98 Carbed
Re: 700R4 pump
Great explanation. It makes so much sense now why you need to turn the converter a bit to get it to seat.
Re: 700R4 pump
I'm glad to have helped . If you ever need to see any of the other internal parts of our transmission I have a sticky thread at the top of the transmission page where I took a 700R4 down to "parade rest" and photographed each piece with a regular Bic lighter in each shot for size reference . Joined: Aug 1999
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: 700R4 pump
I re-built a 4L60E about a year ago and for some reason, that pump did not want to re-seat properly when I tried to put it in the tranny. I brought the pump to a tranny shop and asked them to clamp/bolt it together so I know that wasn't the problem - and it DID finally fall into place properly - but it still took many attempts before it slide into place.
Car: 1985 Z/28
Engine: L98 Carbed
Re: 700R4 pump
I used two really long hose clamps to center both pump halves together. When I put the pump in it lined up great. It was just slightly snug once it got to the rubber seal. I didn't have to crank it really hard at all.
What was was stopping the pump from lining up initially was that the drum(I'm sure I'm using wrong terminology) was cocked to one side. This was caused by the steel band around it. It wansnt sitting properly in the case. Once I wiggled it slightly in centered.
