700r4 TCC Lockup Wiring, please Help?
Old Jan 19, 2017 | 10:54 PM
Skyler11's Avatar
Hi everyone, I first wanted to say that I don't have a third gen. it's a c1500 pickup. I never get answers back from Fullsize Chevy. I have done major things to this truck, engine swap, tranny rebuild, exhaust, Carb swap (HOLLEY 4160), suspension rebuild, loooootts. Now i just want my lockup back, and I need help with the wiring. I know I can get a vacuum switch and all that fancy stuff, but funds are gone, no job, all I have is a Toggle Switch. It is an 89 Tranny, I know that has a big part in this, I know there is the purple, lt. blue, and tan/black wires. From my ATSG manual (TRANS MODEL MZM) there is a temp. switch, 4-3 downshift switch, 4th clutch switch, and two wire tcc solenoid. I would also like to have the brake switch disconnect the circuit when brake pressed. Does anyone know where I can find GOOD diagrams, or could help me through this.
I'd appreciate the help and advice.
Old Jan 19, 2017 | 11:09 PM
Skyler11's Avatar
Re: 700r4 TCC Lockup Wiring, please Help?
Here is a photo of the internal wire harness.
Attached Thumbnails 700r4 TCC Lockup Wiring, please Help?-img_20170119_220008.jpg
Old Jan 19, 2017 | 11:23 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Use the Search feature in this forum
Search Term = TCC
User = John in RI
I've replied to a couple threads over the years about TCC lock-up. Not that my info is what your looking for ( might be ) but it will give you a good list of threads to read thru.
Good Luck !
Old Jan 19, 2017 | 11:26 PM
Skyler11's Avatar
I have been for about 3 days. Not finding much about an application like mine, but I'll keep searching. Thanks though.
Old Jan 20, 2017 | 06:48 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
You may not find wiring diagrams for your truck on these pages. May have to resort to buying a factory service manual for your truck. That will have what you need so you can properly locate the wiring in your truck.
Yrs ago I did a tpi swap on a 1990 1500 and had to use the service manuals from the dealer.
Old Jan 20, 2017 | 02:06 PM
John in RI's Avatar
If you locate the answer using the search terms I posted,... You will not find it on this Website.
Old Mar 10, 2017 | 12:49 PM
Skyler11's Avatar
Well I got it together finally. Sorry I have been helping my parents lately. What worked was. Jump the blue wire to the ecu ground wire. Ground edu wire to a good ground. The purple wire from the brake switch to the trans harness gets spliced and a toggle switch added. I now have lock up in 2nd 3rd and 45th (: thanks guys!
