Possible bad pilot bushing?
Old Feb 25, 2017 | 02:15 PM
Abubaca's Avatar
So I'm getting a strange whine/squeal coming from the clutch/trans area, and I can easily feel the vibration in the shifter. Happens when the car is IN gear, and the clutch is NOT engaged/pedal on the floor. It's not a grinding sound, but when it happens, it's fairly loud and un-nerving!! I haven't "stayed in it" so to speak to see what happens, but a quick shift into neutral stops it. Going right back into gear and all is fine. Had the car out for a few hours this AM, and it did it twice. Once while stopped as I shifted into R, and once at about 50mph. I pushed the clutch in to shift and it happened....I immediately released the pedal and it went away. Pushed the clutch right back down and no issues, it shifted smoothly.
It's happened about 5 or 6 times total over the past month or so. It's a TKO, and for what it is, the trans is smooth as can be expected. No issues. Clutch is a Ram HD with probably 500 miles on it.
Thoughts?
Old Feb 25, 2017 | 03:42 PM
Biledriver's Avatar
Car: 87 firebird 86 c10 90 mustang
Engine: 383 sbc
Transmission: 97 t56
Axle/Gears: Moser 12 bolt 3.73
Re: Possible bad pilot bushing?
Sounds like the pilot bearing. Next time it happens see if it stops as soon as you let the clutch go in gear. It can only make noise when the engine and trans are not moving the same speed. If you use a roller bearing you can't let that keep going.
Old Feb 25, 2017 | 04:59 PM
Abubaca's Avatar
I will pay attention and do that. ...it DOES however start IMMEDIATELY with either the pedal being pushed in OR, pedal already down, and I place it in gear. Both would suggest pilot I think.
I do NOT use a roller. Too many horror stories. ...with a bushing, if it's not doing this very often, am I ok? ....or does it have to come out regardless. Most days it doesn't do it at all. Today it did it twice. Gonna drive tomorrow, and of course I'll be lookin out for it.
Old Feb 25, 2017 | 08:01 PM
Biledriver's Avatar
Engine: 383 sbc
The bushing must be dry. If it's not very old Input shaft may not be going deep enough. When you get a chance to pull it out you should be able to see for sure from the wear pattern how deep the input shaft goes into it. I had to get a extended bushing for mine.
Old Feb 26, 2017 | 11:55 AM
big gear head's Avatar
There are a lot of cheap junk pilot bushings out there now. If a magnet sticks to it then don't use it. You want a bushing that is made from oil impregnated bronze. The cheap junk that's out there now has iron in it and they can damage the input shaft of your transmission. If you can't find a good busing local then contact AGE AutoGear and get one of their bushings.
