T5 drain and fill
Old Mar 6, 2017 | 08:30 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
T5 drain and fill
I have done the shiftier removal and the squeeze bottle method of fill and also used a brake bleeder to suck out the extra fluid but this little pump was the way to go. Fits the standard Qt bottle and the taller Qt bottle, filled the trans fast with no mess and helped to drain that extra bit that sits at the bottom. Totally worth the $7
Amazon Amazon
Old Mar 6, 2017 | 08:57 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: T5 drain and fill
Works the other way too, but those pumps don't fit Redline bottles.
I use those bottle pumps to empty PS pumps as well. Handy things those are.
When I was younger and more stupid, I siphoned the gear lube out of a '63 Pontiac rear end (there's no drain plug). Took half a day to get it drained.
Old Mar 6, 2017 | 08:59 PM
midias's Avatar
They fit Royal Purple bottles perfectly. You might want to just save an oil bottle sometime and fill it up using the redline stuff and then pump
Old Mar 6, 2017 | 09:08 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
I use empty Pennzoil bottles.
