7.5" Part Numbers
Old Mar 6, 2017 | 01:39 PM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
Axle/Gears: 10 Bolt 3.73, Torsen Diff
7.5" Part Numbers
Does anyone happen to have a list of part numbers for the seals, races, bearings, crush sleeve, etc?
More specifically, I'm looking for the pinion bearings and races, but I feel like we should have a fairly comprehensive list here somewhere. I spent around 10 minutes searching through threads but I just couldn't come up with anything.
Old Mar 6, 2017 | 03:45 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: 7.5" Part Numbers
Most people just buy a kit it is easier and comes with everything
This is my favorite, comes with all the stuff you mentioned Other than that autozones website can give you a list easy
Amazon Amazon
Cover Bolts: 10
Ring Gear Bolts: 10
Pinion Spline Count: 27
Cover Gasket Included: Yes
Pinion Shims Included: Yes
Carrier Shims Included: Yes
Crush Sleeve Included: Yes
Pinion Seal Included: Yes
Pinion Nut Included: Yes
Ring Gear Bolts Included: Yes
Head Bearing Included: Yes
Tail Bearing Included: Yes
Carrier Bearings Included: Yes
Axle Seals Included: No
Axle Bearings Included: No
Quantity: Sold as a kit.
Old Mar 6, 2017 | 04:23 PM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
Lots of kits, for sure. Unfortunately, I've already replaced everything aside from the pinion bearings and seal, so there's really no reason to buy a kit.
Old Mar 6, 2017 | 06:48 PM
midias's Avatar
Like I said look on autozones website
http://www.autozone.com/drivetrain/p...eVehicle=false
Old Mar 7, 2017 | 01:33 PM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
Well, I figure it can't hurt too much to have a somewhat comprehensive list of part numbers on the forum somewhere. There's plenty missing from this list. If any of these are wrong or if anyone has anything to add, let me know and I'll update this.
Code:
				NATIONAL	AC DELCO (TIMKEN)	TIMKEN		YUKON		USA STANDARD GEAR	SKF		DORMAN
Rear Wheel Bearing		5707		RW2009 			5707
Rear Wheel Seal			8660S		291309			8660S
Differential Bearing		LM501349
Differential Race		LM501314
Outer Pinion Bearing & Race	A-34		S9
Inner Pinion Bearing & Race			22510042
Inner Pinion Bearing		HM89249
Inner Pinion Race		HM89210
Pinion Seal			8610					8610		YMS8610		USA30192
Pinion Nut										YSPPN-018	USA33152
Pinion Nut Washer											USA33167
Crush Sleeve												USA33110				81058
Speedi-Sleeves															99152
Old Mar 7, 2017 | 02:05 PM
midias's Avatar
Yukon (YSPPN-018) Pinion Nut
Yukon (YMS8610) Pinion Seal
SKF 99152 Speedi-Sleeves (yoke grove fix)
