th200 to th350
Old Mar 25, 2017 | 08:03 PM
thrdgncamaro's Avatar
Car: 1983 Camaro Base
Engine: 4.8 LS POWA and CHINA boi turbo
Transmission: TH350 w/ Shift kit 3200 stall
th200 to th350
I swapped out the th200 that came in my car and installed a built short tail th350. I bought the UPI cross member that moves the torque arm already. Do I need to get a longer drive shaft? If so is there a year camaro that i could get one from that would work?
Old Mar 25, 2017 | 08:49 PM
Re: th200 to th350
DS should be the same.
Old Apr 8, 2017 | 05:34 AM
Rotti54's Avatar
Re: th200 to th350
Not to steal this thread, but I'm looking to do the same Swap. What is all involved soup to nuts. I have an 82 Trans Am with the TH200 looking to go to a worked TH350. From what I understand I need the following parts:
1. TH350 with short 6" tailshaft
2. A cross member/adjustable torque arm UMI OR BMR?
3. Adjustable kick down cable B&M or Lokar
4. Reuse my factory driveshaft until I can ha Eva stronger one made that will handle more HP
am I missing anything else???????
