final drive assembly
Old May 13, 2017 | 03:37 PM
A.vassell's Avatar
Want a title? Post!
what happen to a car performance when a differential gear teeth is damage?
Old May 13, 2017 | 04:09 PM
GeneralDisorder's Avatar
Re: final drive assembly
"Performance".... well it typically won't perform at all.... least not for long.
If the teeth are damaged then you will hear gnashing and grinding, and other ugly noises followed by popping, jerking, locking up, and generally pretty violent unhappy behavior, followed by the car refusing to move at all.
GD
Old May 16, 2017 | 11:32 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Also the torque arm in these cars will often make it sound like it is coming from the trans area. You will hear a lot of noise that will change with how much gas you give it. If you have a manual and push in the clutch the noise will often disappear or get much less. Then again I drove a truck with 3 ring teeth rattling around the diff 400 miles to avoid towing fees and it worked just fine although noisy. Pull the cover and see what it looks like
Old May 16, 2017 | 12:15 PM
big gear head's Avatar
What kind of damage are you talking about?
Shep5B
Dec 20, 2016 12:06 PM
cosmick
Oct 29, 2016 08:21 AM
855speed
Oct 2, 2016 01:44 PM
Wafflestomp
Sep 22, 2016 09:30 PM
TRAXION
Aftermarket Product Review
32
Dec 20, 2000 03:34 PM
