Steering fitment issues
Old May 17, 2017 | 04:27 PM
shaynecastongua's Avatar
Car: 1985 Trans Am
Engine: Chevy 355
Transmission: T5 NWC
Hey guys, I have an 85' Trans Am that I'm restoring. I finished up changing the pump and redoing all the power steering lines today but it seems that the input shaft to the power steering box and the steering wheel shaft are separated. Based on the shape of both of them, they look like they should mate, but I can't figure out how to move them closer to one another. Am I missing a piece?
Attached Thumbnails Steering fitment issues-20170517_165506.jpg   Steering fitment issues-20170517_165510.jpg   Steering fitment issues-20170517_165523.jpg
Old May 17, 2017 | 04:28 PM
Car: 1985 Trans Am
Engine: Chevy 355
Re: Steering fitment issues
Also please disregard all stray wires/lines. This is definitely a work in progress.
Old May 21, 2017 | 08:28 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
looks like its just pushed up inside...
Old May 21, 2017 | 10:44 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Your column has two shafts, joined together inside.
They are typically adhered together with a plastic meant to break in case of collision (So the driver is not speared.)
The bottom shaft easily shoving up into the main column means it may have been in an accident before. A replacement column, or major tear down for parts repair is in order.
Old May 29, 2017 | 04:56 AM
Car: 1985 Trans Am
Engine: Chevy 355
Not the news I was hoping for, but thanks for the help guys!
Old May 29, 2017 | 04:00 PM
Car: 1985 Trans Am
Engine: Chevy 355
So I pulled the steering column, I was able to pull the shaft back into position with the column out of the car. Can I just put it back into the car? The shaft seems to be very stuck in place now, and if the safety plastic has already crumpled, wouldn't that make it still safe as the shaft would collapse more easily, but still collapse?
