Tight converter - low viscosity Hydraulic Fluid?
Old Jun 10, 2017 | 08:32 AM
Buickstaged's Avatar
Car: 1984 firebird se
Axle/Gears: 373
So, 700r4 with a tight converter. In the days of racing we used to mix ATF with Tractor Hydraulic Fluid - this was in either the 350TH or 400TH. We could basically change to flash converter stall. Has anyone done this with a 700r4? I know the GN guys use different levels of fluid (200r4) for drag vs street. The converter in the car is very tight - has anyone used the lighter fluid in a 700r4? If yes, what viscosity have you used. Thanks, byron
Old Jun 15, 2017 | 04:08 AM
Pro Built Automatics's Avatar
Re: Tight converter - low viscosity Hydraulic Fluid?
ATF is 7 - 7.5 weight. The hydraulic oil (tractor oil) has been used many times in 700R4's over the last 20+ years. 40% to 100% depending on the type of racing or the use of the transmission.
Old Jun 15, 2017 | 07:49 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I used tractor fluid in my th400 and it tightened the stall up. Not alot but some
Old Jun 15, 2017 | 08:12 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Some people with the TTA with 200R4 use the tractor fluid and have great results.
Old Jun 15, 2017 | 02:01 PM
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
I run 60% tractor fluid 40% Mobile 1 ATF in my 700R4 maybe 100-150 rpm tops less stall on the converter. But trans runs cooler and rear planets get better lube after 20 min at Gingerman raceway trans is about 230-240
Old Jun 17, 2017 | 07:39 AM
Axle/Gears: 373
Thanks to all. Car came out of the Dyno shop last week. Final tune this weekend - then I am driving to Omaha on Wednesday of next week. Looking forward to the drive (430 miles).
Thanks - byron
