T5 tailshaft leak
Car: 1985 Trans Am
Engine: Chevy 355
Transmission: T5 NWC
T5 tailshaft leak
I have a T5 out of an 84' Camaro (Non WC) that I plan on putting into my Trans Am this weekend. I sealed the transmission up, and filled it up with fluid. it was tilted backward so fluid started gushing out of the driveshaft cavity in the tailshaft housing. I looked inside and it appears there is no seal, or at least I can't see one. Is the driveshaft itself responsible for interfacing with the seal at the very back end of the tailshaft housing? There is a seal there, but I'm wondering if there should be another one between the tailshaft and the rest of the tranny.
Car: `86 SS / `87 SS
Re: T5 tailshaft leak
Pretty normal yoke, seal, etc. : https://www.youtube.com/watch?v=O8zYcBpP9xU
The yoke may have a plug tapped in the middle under the u-joint.
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
If the driveshaft wasn't installed then yes fluid is going to come out the tail shaft. The only seal I know of it the one the goes around the yoke when its installed.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Yyup what they said is true also it may help to know that you can fill it easy through the shifter hole before it is installed.
Car: 1985 Trans Am
Engine: Chevy 355
Thanks guys! I thought I was missing a seal and would have to pull the whole thing apart again, phew.
