Automatic transmission bolt pattern
Old Jul 24, 2017 | 12:00 PM
callster's Avatar
Want a title? Post!
I have an 82 firebird, stock automatic transmission. Just found an OLDS 200 will the bolt pattern match. The pan has 11 bolts.
Old Jul 24, 2017 | 12:26 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Automatic transmission bolt pattern
Bop not the same as a chevy
Old Jul 24, 2017 | 12:30 PM
Engine: Lb9
Transmission: M20
Looks like it has a multi pattern case.
http://www.transdepot.net/200R4-2004R-200-4R_c_10.html
Old Jul 25, 2017 | 07:38 AM
The 200-4R is not the same as the "200". The only thing they have in common is that GM used the same #.
The "200" is a 3-speed that has 11 pan bolts. Some if not all had a lockup converter and were known as the 200C. It's the POS that came in late 70s early 80s POS cars, that they somehow thought would be A Good Idea to put behind V8s in these cars in 82 and some in 83. What a YUUUUJJJJE mistake. Back in the day, there was a thriving industry taking those OUT and putting 350s in. It's a very easy swap as such things go: all you really have to change, is to add some way to accommodate the torque arm.
The 200-4R is a 4-speed. Its pane has about 16 or 17 bolts or so... MUCH larger pan, irregularly shaped, and has 2 sort of sumps to it. That's the one that came in the mid-late 80s and has the potential to be a strong runner.
200-4Rs have the "unicase" feature. Not sure about the 200 & 200C. Since the OP didn't tell us whether his car is a 6-cyl or a V8, that just adds to the uncertainty... AFAIK there is NO transmission with both the V8 and the 60° 6-cyl pattern on it. I am only sure that if I had a car with a dead one, I would not care how many bolt patterns it has, because I'd be getting rid of it and putting something else in. Which is what I'd recommend the OP do.
mattbhm
Carburetors
Oct 2, 2016 09:55 PM
merc64
Sep 28, 2016 05:56 PM
retro-roco
Sep 11, 2016 01:46 PM
Josh 91RS
Aftermarket Product Review
Nov 2, 2000 01:05 PM
theformula
Oct 18, 2000 12:46 AM
