Trans experts, wtf is going on here....
Old Jul 25, 2017 | 03:33 PM
manifoldsrme's Avatar
Car: 1985 IROC / 1986 SC
Engine: 305 TPI / 2.8 MFI
Transmission: 700R4's
Axle/Gears: 3.27 Posi / 3.42 Open
I am parting an 85 Trans Am and ran across this (pictures below). Looks like a th350 was swapped in. There is one bolt in the crossmember on each side. There are 13 bolts in the pan which is why I believe it is a th350. But the tail housing has me confused. It looks like it does have the provision for the torque arm, though it also has some ******* setup on the side using an aftermarket clamp as well. Any ideas what is going on here? The whole car was one giant rigged up disaster after another. Ignition, wiring, you name it, if the prior owner touched it, it was cobbled.
Attached Thumbnails Trans experts, wtf is going on here....-img_2258.jpg   Trans experts, wtf is going on here....-img_2259.jpg   Trans experts, wtf is going on here....-img_2260.jpg   Trans experts, wtf is going on here....-img_2261.jpg
Old Jul 25, 2017 | 07:06 PM
Drew's Avatar
Re: Trans experts, wtf is going on here....
Use the transmission pan pattern to approximately identify the transmission.
The crossmember is bolted in upside down. LOL The fubar'd torque arm mount is a nice touch too.
Old Jul 25, 2017 | 07:55 PM
Pro Built Automatics's Avatar
The TH350 has a vacuum modulator on the back of the transmission on the passenger side.
Old Jul 25, 2017 | 09:59 PM
It's a th350 for sure. Has the modulator. I know my transmissions, I am wondering about the tail shaft. Could they have bolted one on from a 700r4? Is that possible? That is my real question.
Old Jul 26, 2017 | 02:44 AM
Yes, we did that years ago. You used the mid (medium) length TH350 output shaft.
