Electronic 700R4 speedo gears/housing
Old Jul 27, 2017 | 07:39 PM
fshutz's Avatar
Im sure this is a beaten path but here it goes (again)- Im changing out the original 2.73 gears of an 1989' t/a w/ an electronic 700R4 Automatic, to a 3.42 & would like to get the speedo in sync. It hard to find speedo parts for the Electronic 700R4 specifically the bigger housing/VSS. Im told to go with the 17 & 44 tooth speedo gears by bow tie overdrives. Im showing the orig. VSS/housing (pictured below) to help in any way. If the 44 tooth I need is correct then Im told I need the "larger" speedo housing -Will the orig. tail shaft accommodate the larger speedo housing w/o needing replaced as well? Also, how do you clock these things if they just lock in place w/ the clamp/hold down in the picture? Looks like they only dial in one way. Lastly, where can you get these electronic VSS/housings, even used? I seen NONE on ebay. The only one I can find anywhere is bow tie overdrives for $75 dollars "used" + S & H. Thanks fellas.
Old Jul 28, 2017 | 06:46 PM
Re: Electronic 700R4 speedo gears/housing
https://transmissioncenter.net/?swoo...edometer-gears Set it to 80 per page to minimize the amount of your life it requires
Old Jul 29, 2017 | 07:46 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
You would have to research it but this might work.
http://www.tciauto.com/tc/speedometer-gear-calculator
https://www.thirdgen.org/forums/engi...3-42-90-a.html
Old Jul 29, 2017 | 08:31 PM
GeneralDisorder's Avatar
This is what I use:
http://www.dakotadigital.com/index.c...rod/prd126.htm
You can change gears at will. Just set the cruise control via GPS and then adjust the box till the speedo reads correctly. Install takes about 20 minutes.
GD
