Differential problems
Old Aug 13, 2017 | 11:27 PM
Kyle Strock's Avatar
Ok so I have a 1991 Camaro rs with a 305 w/ th350 it's got 224xxx miles on it an when ever I shift into drive it jumps I'm at a loss on what to do I've pulled the trans apart an changed the filter an fluids also consider pulling the rear axle apart but don't want to get ahead of myself any ideas?
Old Aug 13, 2017 | 11:41 PM
GeneralDisorder's Avatar
Re: Differential problems
TH350 is not factory for a third gen.... So someone swapped the trans. Is it built?
What's your idle speed?
GD
Old Aug 14, 2017 | 06:16 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Transmission mount?
JamesC
Old Aug 15, 2017 | 06:00 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Idle too high?
Old Aug 15, 2017 | 06:25 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Cable adjustment out of whack. What other things were "improved" when a TH350 was added?
Old Aug 18, 2017 | 05:47 PM
Define "jump".
A 350 cable isn't responsible for any of that, assuming that there's REALLY a 350 in the car. All the 350 cable does, is make it shift down when you floor it.
Old Aug 31, 2017 | 09:09 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
Transmission mount???
