Non cc carb & distributor function
Old Sep 15, 2017 | 05:33 AM
Rhp454's Avatar
Car: 1986 Z-28
Engine: 305cu
Transmission: automatic O/D
Axle/Gears: open, 2:73
I replaced my ccc carb and distributor with a std quadrajet and non computer controlled distributor.
Will my auto transmission still lock up using the manual carb and distributor? How can I tell if my transmission has locked up in overdrive? I have 2:73 gears. Running 60mph I am turning around 1400rpm''s with 235 x 15" tires.
It will not kick down to a lower gear when I mash the excelerator. Is kind of like in direct drive.
Also the engine idles OK at around 800rpm in park, when I put it in drive it almost stalls out. Almost sound like the engine is missing.
