Amazon extruded aluminium finned trans cooler install
Old Feb 25, 2018 | 01:00 PM
GeneralDisorder's Avatar
These fit perfectly under the bumper beam (on my 86 Trans Am anyway):
https://www.amazon.com/gp/aw/d/B01EC4BV4S?psc=1&ref=yo_pop_mb_pd_t2 https://www.amazon.com/gp/aw/d/B01EC4BV4S?psc=1&ref=yo_pop_mb_pd_t2
It is basically a longer (18") version of the same thing Holley is selling under their Mr. Gasket brand. But they want more for the 12" version:
https://www.holley.com/products/cool...be/parts/7365G
So far I don't have any complaints. I haven't checked trans fluid temps but I can't imagine it's any worse than the pitiful single pass tube running through the radiator tank. Mostly I wanted a clean solution for when I go to an all aluminium radiator. Also hated the stock fittings for the hard lines into the plastic radiator tank.
GD
Old Feb 25, 2018 | 08:29 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: Amazon extruded aluminium finned trans cooler install
I have a very similar style cooler installed in the exact same spot. Fits perfectly without impacting airflow to the oil cooler and radiator. The only difference in my install is that I did not cut the tranny lines. I used an adapter to connect the hose.
Old Feb 26, 2018 | 01:36 AM
I wanted to keep the majority of the hard line routing as it is slimmer and cleaner and my oil pan hangers are still in good shape, etc. I also figured that I could use the other end of the hard lines to create adaptors should I elect to run though the radiator cooler in addition to the external cooler.
Have you checked temp before/after? My plan is to stick a temp probe in the pressure test port on the trans. My race trans doesnt like hot fluid. It was slipping in reverse last summer when hot.
GD
Old Feb 26, 2018 | 09:46 AM
GD
No, I haven't. Adding a tranny temp gauge is on my list of projects I need to get around to eventually.
jwdomino
Feb 26, 2018 05:32 AM
dharrison
Jun 24, 2007 08:43 AM
SouthernKnightR
Nov 29, 2003 08:57 AM
SouthernKnightR
Oct 8, 2003 05:42 PM
91GTABird
Sep 29, 2003 04:58 AM
