Trans & motor mount questions
Old Feb 26, 2018 | 07:02 PM
StunMan's Avatar
Car: '91 RS vert
Engine: mild TBI 305
Axle/Gears: 3.43 pos
Finally putting track car only back together. Need opinions on solid motor and trans mounts vs. standard mounts ?
Number one goal is durability of the T5. This is going to be a Lemons car and the number one thing is durability with out spending a lot of money
Have already acquired a Spohn TA and cross member so that is off the transmission tail and directly to the crossmember
Read about flex and movement of the case of the T5 being its week point.
What puts less stress on the trans? Solid or standard?
Old Feb 26, 2018 | 07:35 PM
Jimbonanmis's Avatar
Car: 90 rs 58chevy
Engine: 383
Re: Trans & motor mount questions
Well I'm going to use the energy suspension mount on mine 383 with t5 I'm currently in middle of swapping but I'm going all energy suspension on this
Old Feb 26, 2018 | 07:36 PM
Car: 90 rs 58chevy
Engine: 383
I'd watch out for the solids
Old Feb 26, 2018 | 07:41 PM
skinny z's Avatar
I'd say from a durability standpoint, that a flexible mount will yield better longevity. This is taking into consideration that everything might not be perfect (it is a Lemons car isn't it?) and the flex between mounting points might give some relief to otherwise misaligned, mismatched or highly stressed components.
Old Feb 26, 2018 | 08:36 PM
Solid motor mounts will break motor/trans castings in a stock body car. DON'T. No way those little bolt bosses will hold the car body straight.
Fronzizzle
Feb 15, 2012 05:32 PM
kukerdan
Feb 7, 2011 10:34 PM
SomeGuy25thZ
Feb 22, 2010 07:36 PM
Aviator857
Jun 17, 2009 01:26 PM
91banditt2
May 29, 2001 08:45 PM
