Energy Suspension torque arm mount install
Old 02-25-2018, 05:40 PM
GeneralDisorder's Avatar
I got it done without removing the bracket from the back of the trans - see pics. You need to supoort the rear axle to get it lined back up. I threw some paint on the brackets after grinding off the rivets.
Old insert rubber was pretty hosed
Finished install.
Support the rear axle or you'll never get it lined up.
Always paint bare metal.
After sanding off the rivet head. Used a cold chisel to part the insert from the bracket.
Air powered belt sander makes short work of the rivet heads.
GD
3rdgenmaro
03-24-2010 06:01 AM
ls1>*
02-01-2010 11:51 PM
aaron7
10-04-2003 08:46 AM
TunedPortZ
10-16-2002 01:27 PM
Quick Reply: Energy Suspension torque arm mount install
