Renovated differential questions !
Old May 23, 2018 | 08:18 AM
MATRIX5000's Avatar
Hi I have renovated differential all parts was replaced. I think that works well but still I have heard some voice between speed 80-90 km/h. Like before renovation. The voice is lower but still I hear it.
Old May 23, 2018 | 03:03 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Renovated differential questions !
Are you talking about gear whine?
What is your gear ratio before and after?
What brand parts did you use?
How did the pattern look when the hears were setup.
Old May 23, 2018 | 08:10 PM
big gear head's Avatar
That's a pretty common speed for gear noise. If these were new gears then I would suspect that they were not set up correctly or they were not high quality gears. If they are good used gears then I would say that the pinion depth or backlash, or both were changed when the rear end was put back together.
Old May 24, 2018 | 12:45 AM
MATRIX5000's Avatar
MIDIAS
Yes I told about gear whine.
Ratio was changed from 2.73 to 3.23
Parts form summitracing
DELUXE KIT 7.5 GM RAT-3001K
RING $ PINION SET RMG-4900441
TRUE-TRAC 7.5 GM 3.23 DTL-911A319
Centric 414.64000
Old May 24, 2018 | 06:56 AM
Richmond has a reputation for making noise in this range, but sometimes it's just the way that the gears are set up. Did you do the set up yourself or did someone else do it?
Don 79 TA
Brakes
Jun 25, 2006 04:36 PM
mean 5.7
Mar 24, 2002 07:59 AM
Digger
Mar 21, 2002 06:18 PM
WECoyote
Oct 12, 2001 09:12 AM
TorqueMonster
Sep 12, 2001 01:37 AM
