700r4 won’t shift automatically
Old Jun 1, 2018 | 06:44 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
So here is my issue. My 700r4 will not shift automatically. Here is what it does:
shift into reverse-good
Shift into overdrive- feel it shift but doesn’t move.
same as above with 3 and 2.
shift into 1st, get a slightly harder engagement and it moves fine.
Now, if I drive starting in 1st.... I have to get up to atleast 2500rpms before I can move the shifter forward a click and it’ll shift. Same through all gears.
So all of my gears are there but they will not work on their own.
I checked the governor and it was sticky but I took care of that.
I dropped the valve body and found a couple sticky valves but I cleaned it up and freed them up.
All this and still no change. Tv cable is correct and adjusted correctly.
Please help!!!
I’ve done so much research and can not find any help.
Old Jun 5, 2018 | 07:02 AM
Pro Built Automatics's Avatar
Re: 700r4 won’t shift automatically
Call me when you get a chance early this afternoon. 909 795-1876
Dana
84redta
Dec 18, 2008 11:28 AM
DuronClocker
Jul 4, 2004 04:48 PM
_Iz-
Aug 16, 2002 01:58 PM
dans82bird
Jul 15, 2002 03:38 AM
