Steering Column shaking
Old Jun 8, 2018 | 08:20 PM
Stevenmunoz's Avatar
Car: 1987 Firebird
Engine: 2.8L V6
so my steering wheel is secure but the column shakes a lot when I shake it, more than it should for sure. My advance auto shop thinks it’s the column coupling, what do you think?
Old Jun 9, 2018 | 02:52 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: Steering Column shaking
Tilt screws. Many many articles on here describing how to repair it.
2 types of steering column faults, loose tooth feeling is when the tilt mechanism bolts get loose or fall out. Not that difficult to do, but have to go pretty deep into the column, more common on non-airbag wheels.
Or wheel can be pulled to the 7 O'clock position, but still has spring tension, caused by worn tilt pins, more common on airbag wheels. Same thing, have to go into the column, but not as deep, and the best fix I've used was some over-sized pins.
Camaro kid97
Sep 18, 2014 01:18 PM
SLAYER6669
Jul 31, 2005 10:29 PM
SLAYER6669
Jul 24, 2005 04:16 AM
