maroe624
close
- Join DateSep 2014
- LocationLos Angeles
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car92 Z28 Clone
- EngineVortec 350
- TransmissionT-56
- Axle/Gears3.23 Torsen
- Liked:39 Times in 31 Posts
My 700r4 has a buzzing noise ever since I did my first oil and filter change on it like a few years back. Still shifts ok just that the buzz is annoying Its not an electric buzz more like a physical part moving up and down. Any idea what it might be? Sometimes it slows down and when I rev it, It buzzs faster as I give it gas. It happened after my first oil and filter change when I first got it. Before there was no noise. I'll take a video and post tomorrow, I'm sure somebody has had this happen as well.
Since it started after the filter change that is where I would start. It may be that the filter isn't fully seated. Also, most of the time the old sealing ring stays in the pump bore. Easy to miss this and leave it there.
RBob.
RBob.
sofakingdom
close
- Join DateSep 2005
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- CarYes
- EngineUsually
- TransmissionSometimes
- Axle/GearsBehind me somewhere
- Liked:2,486 Times in 1,898 Posts
Yup, sounds to me like a leak at the filter neck, and it's sucking in air.
Rule #0 of working on your car: if you work on something and something close by or related that was OK before suddenly and immediately starts screwing up, go back and check your work CAREFULLY.
maroe624
close
- Join DateSep 2014
- Car92 Z28 Clone
- EngineVortec 350
- TransmissionT-56
Yeah I know about the oil filter o ring getting stuck in the bore. I always double check that. And I'm pretty sure that I fully seated the filter but Im' not 100 % sure. I'll post up a video so you guys can hear it. It doesn't sound like a leak to me but who knows.
I think it's next to impossible to get the pan on these things if the filter isn't all the way in, unless you have an aftermarket deep pan
