Buzzing noise
Old Nov 9, 2001 | 03:41 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
Buzzing noise
I've heard that this is sometimes caused by the presure regulator valve. Is this hard to replace and how much will a new one cost me?
Mark
Old Nov 9, 2001 | 09:35 PM
Pro Built Automatics's Avatar
If the PR valve is causing the problem, then you will need to grind a land off the Pr valve as in the Trans-Go instuctions in any of their kits. If you have the 1988 & up transmission you could install the Trans-Go Jr. if you are happy with everything else on how the transmission works. This kit will address the PR valve problem along with fixing the TV system on the 700R4.
Old Nov 12, 2001 | 01:04 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
What was the problem with the TV system??
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
Randomtask2
Sep 7, 2015 05:06 PM
