T56 crossmember
Old Jun 25, 2018 | 10:40 AM
white85transam's Avatar
Car: 85 trans am
Engine: 383 stroker
Transmission: 5 speed
Axle/Gears: 9 bolt rear 3:70
T56 crossmember
Can some identify this crossmember? I bought it a while back for a t56 install but im wondering if its the wrong one. The bolt holes for trans mount is throwing me off as my trans mount has 1 stud not 2 and previous owner definitely used both holes on crossmember.
Old Jun 25, 2018 | 11:02 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: T56 crossmember
I think it is homemade Maybe a Spohn.
Old Jun 25, 2018 | 11:11 AM
Car: 85 trans am
Engine: 383 stroker
Re: T56 crossmember
It's supposed to be spohn and came with torque arm as well. I'm hoping it's for the 4th gen t56 though.
Old Jun 25, 2018 | 05:01 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: T56 crossmember
Most aftermarket transmission mounts have 3 holes, so they can be used with single or dual bolt setups.
Biggest problem with that crossmember is that it will hang down a mile.
Old Jun 25, 2018 | 08:24 PM
Car: 85 trans am
Engine: 383 stroker
Re: T56 crossmember
Can I get a mount that has 2 studs for the swap
Old Jun 27, 2018 | 05:46 PM
Re: T56 crossmember
Looks just like my Spohn.
You could get either a drill bit and add a slot in the middle, or buy a mount for a Turbo 350 or 400, or a Muncie or T-10 4-speed. Any car that came with any of them. Be romantic... aim high... get one for a 69 Chevelle SS396 4-speed. Won't have studs though; it uses 2 bolts instead of stud & nut.
Old Oct 14, 2018 | 12:36 PM
Car: 85 trans am
Engine: 383 stroker
Re: T56 crossmember
I dont believe I was sold the right crossmember for my swap. I tried to line up different holes but the only ones that line up dont match where the trans mount is. Any ideas anyone?
Old Oct 14, 2018 | 12:40 PM
Re: T56 crossmember
Nope, looks like it's for something else... exactly the same except different... 4L80E maybe? What did Steve Spohn have to say when you asked him?
Old Oct 14, 2018 | 01:08 PM
Car: 85 trans am
Engine: 383 stroker
Re: T56 crossmember
I didn't ask him. I was told it was for t56 n came with torque arm too but I dont remember who I got it from on here. I imagine i won't be able to use torque arm either when i get the right cross member
Old Oct 15, 2018 | 01:30 AM
Re: T56 crossmember
I didn't ask him.
Maybe you should.
Old Oct 15, 2018 | 02:09 PM
Car: 85 trans am
Engine: 383 stroker
Re: T56 crossmember
The riddle has been solved. Its for a Borg Warner t56.
Lemonsdemon
LSX and LTX Parts
19
May 29, 2012 09:34 AM
ShMaCk2004
19
Apr 4, 2010 07:28 PM
REVLIMIT
Nov 2, 2002 10:10 PM
