Run engine supported by jack, with transmission removed.
Old Jun 28, 2018 | 11:18 AM
charliemccraney's Avatar
Car: 1988 Firebird Formula
Engine: 305 (LO3)
Transmission: 5 spd manual
To make sure that a new flywheel and pressure plate is balanced properly before complete assembly.
Good idea or should some more ridged means of support to the rear of the engine be used?
Old Jun 28, 2018 | 11:33 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: Run engine supported by jack, with transmission removed.
Ive done it before. Is it best? Probably not. But Ive done it.
Just put a block of wood between the jack and oil pan.
Revs a lot easier!
Old Jun 28, 2018 | 03:04 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
theoretically I don't see why not, just make sure that block of wood doesn't come in contact with the flywheel. I wouldn't bounce it off the rev limiter while doing it but light revs to 2500 would seem fine.
V8Rumble
Nov 3, 2006 02:27 PM
RegaPlanet
Sep 22, 2003 03:08 AM
Camaro_hunter_d
Car Audio
Nov 3, 2001 11:13 AM
