43-tooth purple driven speedometer gear
Old Jul 30, 2018 | 08:49 AM
rt66er's Avatar
Car: 1990 Pontiac Firebird Formula
Engine: L31 350 TPI
Transmission: Tremec TKX
Axle/Gears: 3.23 Posi
Anyone know where I could buy one of these? I recently swapped out 2.73 for 3.23 and went with the supposedly correct 17/44 speedometer gear combo, but my speedometer is off almost 5 percent. 43 tooth should cut that error in half (if my calculations are correct).
Old Jul 30, 2018 | 10:13 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: 43-tooth purple driven speedometer gear
It's 5% slow at 60mph?
If yes, proceed with that 43.
But also see if mile markers and your odometer agree over a 10 mile run.
If it is 5% fast, you need a 45.
Old Jul 30, 2018 | 10:26 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Our speedometers are not always accurate. I would use GPS with your phone to confirm before taking anything apart.
Old Jul 30, 2018 | 11:36 AM
rt66er's Avatar
Engine: L31 350 TPI
Did three 60 mph timed runs over three mile section; averaged 3:086, so the speedometer is 4.7% slow (indicated 60 mph is ~57.2). Admittedly this isn't horrible, but it kinda bugs me. If I can't find a 43-tooth gear, won't be the end of the world. Just thought I'd check and see if anyone had one laying around.
Old Jul 30, 2018 | 11:39 AM
midias's Avatar
Did you use GPS or the internal odometer to measure the miles?
Old Jul 30, 2018 | 03:15 PM
rt66er's Avatar
Engine: L31 350 TPI
Neither, I used a stretch of road that I know is 3 miles.
rt66er
Jul 30, 2018 08:46 AM
Napster134
Jun 20, 2018 10:33 AM
TC3G89
Feb 15, 2016 05:18 PM
habfan
May 5, 2011 09:14 AM
TIMMYS89GTA
Nov 22, 2007 05:50 PM
